I just cant find right option in config section, and probably thanks to that setting i cant get full speed of my connection...
SOURCE: ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
SOURCE: Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
SOURCE: asus wl 600g
How to connect to the wireless network?
Problem connecting to the wireless network?
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
SOURCE: Is it possible to set up the WL-600g as a bridge
Yes. Just set it up as normal but without the DSL entries. It should still act as switch and WiFi AP.
SOURCE: I have a speedport W722V
configure the 600G to a static IP on the same subnet as the 722, and then wire it port to port (say, port 1 to port 1, do NOT use the WAN port) - don't forget to disable the NAT/DHCP on the 600G after you assign it's network IP address (not the WAN address, local address, the WAN port will no longer matter and will be unused on the 600G)
