I have a kenmore Model 110 2483 2200 and it leaves lint on dark clothing. I'm considering replacing the machine. I have a kenmore Model 110 2483 2200 and it leaves lint on dark clothing. I'm considering replacing the machine.
You can't post conmments that contain an email address.
Be sure to seperate lint givers with lint taker, do not mix towels etc with clothes that are attracted to lint. Also be sure water levels are sufficient
Does your machine has side panels in which lint gets deposited and comes out in the main rub when you start washing.? thats my problem these days. I have Kenwood KWM 950 SA.Does your machine has side panels in which lint gets deposited and comes out in the main rub when you start washing.? thats my problem these days. I have Kenwood KWM 950 SA.
Black spots on clothes from a washing machine can be caused by several issues:
Detergent buildup: Clean the detergent dispenser to remove any buildup.
Hard water deposits: Install a water softener to remove minerals that can leave spots on clothes.
Lint buildup: Clean the lint filter to prevent lint buildup.
Poor-quality detergent: Switch to a high-quality detergent.
Agitator problems: Check the agitator for any damage or issues.
If the issue persists, it is recommended to have a professional technician diagnose and repair the problem as it may require technical skills and specialized tools.
These washer are notorious for linting, there is no real solution, reduce wash time to bare minimum, try sorting clothes into different categories, whites separate washed from dark clothes, use good quality detergent. The only way to fix this problem completely is a neutral drain kit, I do not believe Maytag sells one.
The white streaks are of soap build up on your machine tub. You can get ried of that by putting cascade dish washing soap in your washing machine and run full cylece , with out clothes.
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
you can buy lint filters from f&p but your main problem is caused by something like a tissue or something like that disintergrating inside ur machine best thing to do is remove inner bowl and thougherly clean both
