U-Line 15R Compact Refrigerator Logo
Posted on Jan 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
(1.7 cu) Chefmate Fridge Doesn't Get Cold
I have a small Chefmate fridge that I got at the beginning of college and has since stopped working. It stopped blowing out cold air and instead blows out air at room temperature, keeping anything inside the fridge from getting cold. Any help?
  • 2 more comments
  • pat_montalv Jan 14, 2009
    I don't hear anything coming from the compressor, should I try starting it over and over again (and by that do I mean plug and unplug again and again)? If that's not the case I take it I should calla technician?
  • pat_montalv Feb 05, 2009
    Where exactly is the compressor located (dumb question I know)? I've unscrewed the back of the fridge and everything seems to be intact and fine, just a good amount of dust build up but I cleaned most of it out. Still doesn't quite work but I'm open to suggestions..?
    The fuse doesn't look like it shorted (but I'm not exactly sure how to tell). I cleaned all of the dust and debris from the inside but it doesn't look like anything is wrong with it? Any other suggestions?
  • Anonymous May 15, 2013
    Mine is not cooling, the fan is not working but there is light when I open the refrigerator. I guess I am lost...
John Powell
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on May 27, 2009
John Powell
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
42339
Points
30
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9823
Points
I fixed my chefmate 1.7 fridge by directly applying 12 volts with a laptop charger to the wires leading to the thermoelectric device. If you keep those wires connected to the circuit board, it will power everything else. however, it seems like your problem is in the thermoelectric device. You can get a replacement at amazon.com for 5 bucks. the part number is TEC1-12706 you can learn how to replace it with this video: http://www.youtube.com/watch?v=KBhVS7GhCOM&feature=related Good Luck!
Anonymous
Level 3:
  • Master 716 Answers
  • Posted on Jan 12, 2009
Anonymous
Master
Level 3:
Answers
716
Questions
Helped
365483
Points
2094
For some reason or another the compressor may not be starting. If you get right down and check it you may hear what we call "cycling on the overload". This is a click, a pause, then a pop which repeats every minute or so. This can be caused by a cooling fan that doesn't work, a relay, or the compressor itself burnt out. You can check the fan if present by starting it ten times in a row, (it should start each time). Depending on your situation you could try a new compressor starter and if that won't do it you'll know it's the latter case.
If the compressor does in fact run, in the situation you describe, you have a more serious hermetic system problem. This is something you have to call a technician in for to get a better idea of the cost for repairing this one.
Hope this helps.
  • Anonymous Jan 14, 2009
    Yeah Plug In And Unplug It You Should Hear The The Humming Sound Of The Compressor. Just Put Your Ear Against It. If Thats The Case Yeah You May Need To Call A Repairman.
Anonymous
Level 1:
  • Posted on Jan 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
9823
Points
The compressor has a fuse right on it it may be shorted out check the fuse i had a fridge that had the same probloem and replacing the fuse fixed it
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Ondesit fridge fridge freezer biaa134fh fridge not cold
It seems lots of people have the same problem with this appliance....including myself......I took the drawers out of the freezer.....removed the iced up plastic cover which houses the fan assembly.....some water had settled in the bottom and froze, therefore stopping it from turning.....just spin it and it with start up again.....hope it helps ;)
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
My freezer is getting cold but the fridge is not getting that cold what do i need to do? the motor is working
Hi, Try to defrost the fridge. Sometimes air flows stops due to access of ice in the freezer. Try to defrost it and see if it works.
Regards, polysandy
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
