SOURCE: westinghouse silhouette frost free 522 fridge is
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
SOURCE: my westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
SOURCE: Westinghouse side by side refrigerator
Hi!
The Ice maker is an independent device and can be removed and fixed separately from your unit. Remove icemaker's two 1/4" hex head fastening screws and unplug the electrical connector. Visually inspect unit looking for broken or loose retainer, arm or strip arm or defective ice mold. Click on the following link to see an exploded diagram with the parts names and prices. If the price of the unit parts amounts to over $100, you may consider replacing the whole unit. http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GD5RHAXNB00/1198/0165000/W0409046/00012?blt=06&prst=&shdMod=
Your unit model GD5RHAXNB00 was made by Whirlpool/Westinghouse.
If you need further assistance, just place a comment.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
SOURCE: 1973 Westinghouse side-by-side refrigerator is
You have either a clogged drain trap or a bad drain trough heater.
