Toshiba Tecra M2V-S330 Notebook Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove built in wireless card on Toshiba Tecra M2v-S330
Can anyone tell or show me how to remove the built in wireless network card on my Tecra M2V-S330 laptop? The card apparently failed, because every time I turn it on, it crashed the computer and I get the blue screen of death with an ''IRQ not equal to or less than'' failure message, and it reboots.
Anonymous
Level 2:
Sergeant:
  • Expert 366 Answers
  • Posted on Jan 11, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
366
Questions
0
Helped
125938
Points
831
Assuming you are in XP:
Start in safe mode and either try to fix your Configuration (did you installed anything conflicting with you WLAN card?) or simply disable the card from your configuration in Control panel, system, Hardware tab, Device manager
Check if an updated driver exists for your card: latest SP3 is sometime conflicting with older device drive.
Let me know if working and do not forget to rate the solution
Cannot detect wireless card on toshiba tecra m2v S310
Rarely does a drop result in a positive result. That said, Open the laptop and check for a loose connection and reseat the wireless adapter. In the Device Manager is the Wireless Adapter listed it Network Adapters? In Network Places, Is the Wireless Adapter there? Tis video may give you a starting point: http://www.youtube.com/watch?v=WVJHbvBoIkg
1helpful
Can you upgrade the processor in the Toshiba tecra m2v s330? will the motherboard recognize-handle an upgrade? what are the specs on the motherboard, a link or page would be helpful.
Your Toshiba Tecra M2V-S330's motherboard is capable of handling Intel Pentium M 1.40, 1.50, 1.60, 1.70, 735, 745 and 755. You may double check your computer full specifications and options through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
There is a flashing amber light on the power light on my toshiba tecra m2v-s330,and the laptop does not turn on...what should i do ?
Motherboard's dead. Best bet is to replace it. Best source for these things is eBay. Around $30 delivered.
Cómo reseteo el password del bios de una tecra m2v-s330
allez retournez a cette page
"ErusTownsend"---Fixya "Dieu"
puis a "
Remove BIOS Password on Toshiba "Si vous souhaiter cette "Dieu" etude cette page!
I want the infared driver for Tecra M2v s330
download them from toshiba site like http://nl.computers.toshiba-europe.com
Where and how do i replace my ram on toshiba tecra
Hello.Shut down the laptop. Remove the rams.Put the new one. It depends on how many slots you have. If you have one memory slot just put it there.The original 256 can stay there.
1helpful
Toshiba Tecra M2vS330- crashes when wireless card switched to "on
Hi, your problem does not have to see with the openoffice that download, It coincides with your card mini - pci wireless I damage, and is for it that whenever you ignite the wireless your Laptop restarts for hardware malfunction. the solution is to replace the mini wireless board.
Wifi connection
Hello. The wifi switch should be on as indicated by the light beside it. Please press on Start-Connect to  - then select a wireless network then click Connect. If you are asked for the password, please enter it. Click on Open Network and Sharing Center to check if there is a red x mark between the network and the internet or between the network and the computer icons. If there is none, please launch your internet explorer. Hope this works. Thanks.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
