Irons Logo
Denise buchmuller Posted on Nov 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having problems with my cord when I move the iron the iron shuts off. How do I fix this problem? DM880.
francoise cleofas
Level 3:
Genius:
  • Irons Master 2,432 Answers
  • Posted on Nov 30, 2012
francoise cleofas
Irons Master
Level 3:
Genius:
Answers
2432
Questions
0
Helped
298419
Points
6852
Just replaced the power cord, you can buy wire and plug then assembled it to the iron and replaced the old power cord which may cause of shut off.
  • Denise buchmuller Jan 02, 2013
    We replaced the power cord and that fixed the problem. Thank You.
  • Anonymous Mar 25, 2013
    were did you get the replacement cord?
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Mar 06, 2009
SOURCE: iron not staying on
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Anonymous
  • 18 Answers
SOURCE: Rowenta DM880 Auto shutoff - Shuts off too frequently
Anonymous
  • 19 Answers
  • Posted on Aug 16, 2009
SOURCE: I live in Little Rock Arkansas, where can I get
there are screws that hold the wire down under the cover sounds like the metal tip on one of the wires has broke off
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 12, 2010
SOURCE: Power cord sparked and burnt. What tool do you
They are called TORX screws. You need a torx set of drivers.
Anonymous
  • 43501 Answers
  • Posted on Jul 14, 2010
SOURCE: DM880 Rowenta Professional Luxe Iron
The thermostat is bad...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
The electrical cord seems to have come loose near the iron itself causing the iron to shut off. is this a known problem & how do you fix it?
This has been happening since the first cord was attached to the first electric iron. The cord takes a beating. You will have to disassemble the handle and fix it ... or get a replacement.
Rowenta iron won't heat
heatman101
4helpful
2answers
heatman101
5helpful
Iron not staying on
Rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Top Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Iron Expert? Answer questions, earn points and help others
