Can someone please tell me how to remove the agitator from my EWT806 Electrolux washing machine??
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
SOURCE: My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
SOURCE: centrex washing machine ctw60519
The agitator is only stiff. Do not lift from one side only.
Loosen the centre with some CRC, spin by hand a few times. Then place a hooked pice of strong wire under tow opposite edges and lift.
SOURCE: help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
