Electronics - Others Logo
thescigeek Posted on Nov 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HPv165w recognized in Device manager...But cant open it in My computer..
I have a HPv165w 4GB pendrive...1.5 years old...I inserted the pendrive onto my PC...The icon in MY COMPUTER shows removable media(instead of the name i've given it)..I clicked on it to open and MY COMPUTER window became responsless...I removed the pendrive and system came to life again..I inserted the pendrive oncwe again..But instead of clicking on the icon in "Mycomputer"..I opened the device manager and checked the disk drives..I saw the name"hpv165w" indication that my pc has recognised it and opened its properties in device manager,which told that the device is working properly..So I opened My computer and saw the icon Removable media(j:),clicked on it and again the MY COMPUTER(not responding).....Pls tell a solution to this problem as fast as you can....
Lawrence Oravetz
Level 3:
  • Electronics ... Master 10,558 Answers
  • Posted on Sep 24, 2014
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2700135
Points
29284
Did you give your computer enough time to read all the files on the drive? Vista and XP are notoriously slow at reading an external drive. It reads every file on it before it shows anything in the directory for the drive letter of the drive.
Anonymous
Level 3:
  • Master 32,281 Answers
  • Posted on Nov 24, 2012
Anonymous
Master
Level 3:
Answers
32281
Questions
Helped
7912877
Points
102259
Try inserting the pen drive into another computer to see if you can open the data on this pen drive.
If not you may need to format the pen drive.
1 Related Answer
Bob
  • 245 Answers
  • Posted on Aug 10, 2010
SOURCE: i have transcend 4GB pen
Try the following link for a utility to help you out.
http://www.freedownloadscenter.com/live/how-to-format-transcend-pen-drive/drive.html
My transcend 4gb pendrive, JF V10 is not working at all. my pc dtects the drive, but i cant open it. "please insert disk into drive" - pops out. 0 bytes is shown when i view the properties....
Right click on my computer , left click manage , click storage - disk management
in the top section of the window see if you can see your pendrive .. if you can then check the drive letter it was assigned , then check if one of your other drives hasn't already being assigned that letter , if so right click ont the pendrive in disk management console - select change drive letter and paths..... -
select a another letter for the device - one that hasn't been used yet
reply if u were unsuccessful
thanx
I have 4gb tosibha pendrive. when pendrive insert into my computer it recognized but it shows 0 bytes and also it can't formate.
Right click "MY COMPUTER" then go to properties and then hardware and then device manager.
Make sure you have no yellow "exclamation point" symbols next to any devices.
IF that doesn't work you will need to try and format through linux based OS or try KNOPPIX linux (boot cd)
If none of those options work the pendrive is dead.
Please rate if this was helpful
Format my new transcend 4gb pendrive
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
"insert a disk into drive"
right click my computer
manage
in right panel double click storage
double click disk management(Local)
right click on the pen drive shown and click format
Transcend pendrive
you just uninstall that unkown device which you get in device manager and reconnect the pendrive if again it says unknown device then goto update driver and select 2nd option which is advanced in that select don't search for driver i'll select and select the driver which is shown in the list and click next and finish ur pendrive will works
Kingston DT1000 pendrive was not detected in computer
hi there.
this is what i have just found on the internet it might help you out but not sure.
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
2helpful
2answers
Recognized my 4gb transcend pendrive
Try windows repair, it should fix the problem.Else connect the pendrive and check the port settings.You can check for the port settings by
right click on "my computer"-->properties-->hardware-->device manager
A new window opens and at the bottom probably you'll find "Universal Serial Bus controller". Expand that option and check whether all the ports are enabled.If the pendrive is still not detected, then the problem is with the port.Check the same with the other available ports.Any further doubts add comments.Would be glad to answer.Good luck.
6helpful
3answers
Transcend 4gb pen drive not getting detected
pen drives generally have 3 to 5 years warranty, if your pen drives are not detectng on other systems also, its better to replace it
1helpful
5answers
Pendrive is not working
I agree with geokohler...
removing the original software on the device many times allows said device to be used on any computer, obviously once the software is removed the devicxe will need to be reformatted!
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
