ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1984 1985 1986 1987
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue Switched 12V+: Yellow/Red Ground: Black Illumination: Red/Black Dimmer: n/a Antenna: Driver's Pillar
Front Speakers: Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black
Rear Speakers: Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a Metra Brand Wiring Harness: 1984, 1985:70-1388 1986, 1987:70-1720 Metra Brand Antenna Adapter: n/a
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake Switched 12V+: Black/Yellow - Ignition Switch Harness Ground: Use Chassis Near Cruise Control Module Hot Side of Brake: n/a - Brake Switch Cold Side of Brake: Green/White - Brake Switch Tach: Blue - Coil VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1983 Honda Civic
CRUISE CONTROL:
NOTES: 4000PPM
check and make sure both fans are working properly. you can do this by jumping it directly to the battery and see if it comes on if it doesn't the fans need to be replaced.
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic
1980 1981 1982
Constant Power: White/Blue Switched Power: Yellow/Red Ground: To Chassis Metal Illumination: N/A Dimmer: N/A Antenna: Drivers Side Pillar
Left Front (+): Red/Green Left Front (-): Brown Right Front (+): Blue/Green Right Front (-): Gray
Left Rear (+): Red/Yellow Left Rear (-): Brown Right Rear (+): Blue/Yellow Right Rear (-): Gray/White
NOTES: - none -
Metra Brand Dash Kit: n/a Metra Brand Wiring Harness: 70-1388 Metra Brand Antenna Adapter: n/a
NOTES: 4000PPM
a couple things should be checked but the thermostat should be the problem if not check all hoses for blockages or the actual radiator. you have tackled the most expensive part of the cooling system already so start with the cheapest part and most prone to failure the thermostat.
these are codes you need a call the dealer talk to service and give them the codes they should tell you these problems also you can buy the boodk from the parts store and look for these cods
I found instructions to do this for my Lexus on clublexus.com. Here are some ideas for you to check. The search tool is a great thing on these forums you should most likely find it at any one of these three sites www.hondacivicforum.com www.civicforums.com www.clubcivic.com
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
