SOURCE: My husqvarna 225B leaf blower starts easy when
A few possibilities, first check the tiny little vent hole in the gas cap for a clog.Second, check the fuel filter in the tank. Third, remove the muffler and inspect the piston for scores and that the rings are free, remove ant carbon build up from the exhaust port. If the trouble persists its time to go into the carb, The pump and metering diapgragms will harden over time and loose their elasticity and cause this problem also
SOURCE: runs rough at high power
clost the choke slightly and see if it smoothes out. If so then it is a lean condition. Check fuel lines and/ or rebuild carb
also check the screen in the muffler. If it is clogged clean it.
SOURCE: husqvarna 356 backpack blower,when it gets hot it
Hello. You may have a partially gummed up carburator. Get a bottle of SEAFOAM at the auto parts store. follow the directions about how much to add and add it to your fuel. Run a couple of tanks of this enhanced fuel through your blower and it should be aok. Regards, Joe
ps - kindly rate my answer. thankyou.
