You have a faulty water valve turn the cold water off at the main see if the water is still dripping in if it is it will be the hot water valve replace faulty valve they are fairly cheap to buy best to replace both piece of mind you can buy them on line and are easy to replace euro spares will have them if you still need help let me know.
SOURCE: how do i remove the soap drawer
Hi, I had the same problem, Open the drawer fully by pushing the right hand side in to release.
With the tray fully open, hold the white front bit steady and pull drawer bit, hard towards you. Quite a lot of force is needed.
Its held in by a plastic clip that clips onto the hinge part of the front cover. Hope this helps took me 3 months to take the courage to pull hard enough.
SOURCE: w123 dispenser drawer keep melting
Hi there you can order the part from indesit and should not cost alot and yes it should withstand the temp check that if you are using the hot tap to the machine turn down the water thermostat as maybe too hot.
Thanks J
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
SOURCE: My washing machine overfills on
Possible fault of the wateer level sensor that is allowing the water to go beyond when the pressure switch is contacted. you might have to remove the level sensor and set it low so that the levels are cut off or use the low level settings to see how much water comes into the wash.
If with the low settings the high level is reached you can use this for some time till it fails.
Try this and respond.
SOURCE: I own an Indesit WIXE167 washing machine, recently
Indesit 'F05' normally means that there is a drain blockage and no, you should not have to purchase another washer!
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
