Fossil FS2990 Wrist Watch Logo
Christine Lebensieg Posted on Jun 03, 2007
Fossil ES1592 The back of my fossil watch ES1592 was removed for battery replacement, and now I can't get it back on. I have several fossil watches that I purchased from EBay, and it is almost cheaper to buy another watch instead of replacing it with a new battery. At any rate, can you tell me how to get the back of the watch on? It snapped open with my watch repair kit, but will not go on now. Thanks
  • 2 more comments
  • salvete Nov 29, 2007
    I have the same problem with my Fossil LI-2339, I talked to fossil and they told me it would be $12 to replace the battery, I thought I could do it myself easily enough but when I opened it I found three batteries, the store told me that the $12 charge included the price of all three batteries... wish they would have told me that when I asked originally. Since I can't get the back on, I'm taking mine there and letting them do it all. I saw someone say having them do it is usually more expensive than buying another watch, but $12 for three batteries and to get the headache off my hands sounds like a bargain to me.
  • Anonymous Mar 13, 2014
    What's the replacement battery# for the fossil JR9156 watch?
  • Anonymous Mar 20, 2014
    Will fossil put in a new diamond chip?
  • Anonymous Mar 28, 2014
    Where can I buy another cover for the back of my fossil watch? I replaced the battery and had a hard time getting the cover back on my watch. Two days later I noticed the cover was missing.
riflemenx
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 19, 2008
riflemenx
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1503
Points
5
How do I replace battery in Fossil Twist 1114.
You can simply replace battery in your Fossil Twist 1114 watch. First of all you have to open back case of your watch and remove existing battery. Be careful and do not creates scratches on the watch. After removing existing battery from watch you should place new battery in the watch.
2answers
Why doesn't my new Fossil watch ES 4168 work?
Is it still under warranty for repair?
What battery does the fossil ch2599 watch take
You are going to have to remove the battery to find out which one you need. For instructions on how to do this see: http://www.mademan.com/mm/fossil-watch-battery-replacement-guide.html. You can buy the battery at: http://shop.batterymart.com/search#w=fossil%20ch2599%20watch%20battery. Replacing a Fossil battery is delicate and tricky. Fossil recommends that you send it to a shop that specializes in Fossil watch battery replacements.
1helpful
2answers
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
How do you remove the back of a Fossil watch to change the battery?
good morning ! to remove the case back of your fossil watch,just snap the case back use the knife to do that ! but if your fossil watch is waterfroof design you need to use the wrench opener for treaded watch case back ! good luck ! god bless !...
1helpful
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
1helpful
3answers
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
