Question about LG 37LC7D 37 in. LCD HDTV
Lg 37lc55-za power problem
TV taking nearly 5 minutes to turn on. Stand-by light flashing green.
  • LG Master
  • 6,694 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Posted on Jun 10, 2016
6ya staff
SOURCE:
Anonymous
SOURCE: I have LG 50PC1DR plasma
Hi !..ok you tv problem is in power supply. need be replaced 9 capacitors, (3300mf - 10V) in main power supply board, that fix yu tv..
Posted on Feb 04, 2009
electroman
  • 1039 Answers
SOURCE: lg 32lcd tv's - does not power up - flashing green light
Replace any swolen capacitors on power board. If still not working replaced main board.
Posted on Aug 29, 2009
Anonymous
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
Anonymous
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
Posted on May 25, 2010
freddyb18
SOURCE: LG 37LC2D will not turn on
mine just did this tonight as well.... no answers yet?
Posted on Jul 27, 2010
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
HI, MY LG 37LC55 HAS THE ON LIGHT FLASHING GREEN. ALSO THERE IS NO PICTURE. CAN ANYONE HELP?
maybe your tv has a defect,go to the LG service center ask a technician to fix your tv
Jun 19, 2010 | LG 42PC5D Television
T.V. doesnt turn on and red light keeps flashing at Power Section
Ur power board have dead capacitors,Know how to solders?Take the tv aparts check for capacitors puff up or burst open in the power board.Replaced those capacitors.Or tries Shopjimmy.com,Ebay.com buy a refurbih power board.
Jan 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV doens'nt start
Take to repair shop, must have a loose connection. I am an electronic Tech, 20 years experience. When you turn on a late model TV they do a self test and if they detect a problem then they shut down. I'm not really up on LG, I work for Panasonic and our LED's flash, and depending upon number of flashes it tells you where the problem is. I would suggest phoning LG for the address near you of their Authorized Service Agent. Get the guys who fix them everyday to do the job.
Cheers
Gordon.
Sep 27, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
Green Flashes - Shuts off
Sounds like the green picture tube is defective. To confirm you can take the front grille and door off and tap the green tube lightly with something plastic, and not to touch any of the adjustment controls to confirm.
Apr 12, 2008 | Sony KP-57WS500 57" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
LG 37LC7D 37 in. LCD HDTV Logo
469 people viewed this question
Ekse
RONALD CARTER JR
