It is making a beeping noise and is not functioning. The machine is locked and I can't open it. I tried unplugging it for 1/2 a hour and then holding down the pause button. Nothing is working.
SOURCE: Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol. Pushing & hold both for 3 seconds. This toggles the child proof mode.
SOURCE: Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
SOURCE: I have a he2 kenmore front end loader washing
Something is in your pump trap, easy fix. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Testimonial: "Ffantastic, fixed in under 20 mins!!! Thank you"
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
