1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
S
SOURCE: nokia 2610 wont switch on
u've gotta go to your nearest center to fix your firmware... your program was corrupted and to fix that need the software for flashing your fone
SOURCE: nokia 6300 wont turn on, blue lights on side stay on
I had a simliar problem with my k800i, it turned out that it needed its firmware/software updated. So u can either get it "flashed" at a shop (around £10) or you can try doing it at home but you'll need the software and the data cable for the phone. Google it i'm sure you'll find something. Good luck
SOURCE: Nokia charge without battery (Nokia 5310 XpressMusic)
no,charger provides only battery charging and it does not provide the potential difference for the phone to switch on.try with battery of your friends or some one else
SOURCE: some time ago my battery
There is A Software Problem with your mobile. If your technician then please try to Renew your Mobile software with Related Software Dongle's (For Example : Using JAF Software Dongle or UFS Software Dongle) Using this you can renew your mobile Software.
If your not a technician Then please visit your nearest Nokia Service Center (Nokia Center) they will Help you ok
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up & Testimonials //
Testimonial: "helpful. could I get that software myself?(Im not a technician)"
