Konica Minolta Bizhub C451 Copier Print Scan Color Mfp Logo
Anonymous Posted on Nov 20, 2012
How do I eliminate strange/weird noise?
Strange noise while turning on printer: http://www.youtube.com/watch?v=eat8diO9i1c&feature=youtu.be same noise while printing: http://www.youtube.com/watch?v=i7ETqbRtWi4&feature=plcp Sounds like some kind of plastic is touching some cog wheel or roller. Really can't define is it something near multipurpose tray/fuser side or in the middle where imaging units are, but visual inspection of those parts didn't get me any clue... It started after drums were reset and transfer roller & fuser cleaned from paper dust by minolta technicians. Prints are OK but the sound is really annoying :-(
  • Anonymous Nov 21, 2012
    problem solved. black toner was full of little toner balls & clusters so the toner input mechanism (somekind of cog wheel) between toner cartridge and drum wasn't working well. little vacuum cleaning of that place and changing toner cartridge helped
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 28, 2019
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913018
Points
11959
Have them come back? or try a different company
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Feb 29, 2008
SOURCE: Minolta 2530 DL duplex paper handling
also check that you installed the duplex correctly, that the gears fit into right place. gears are making this sound
Anonymous
  • 12 Answers
  • Posted on Apr 06, 2009
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Anonymous
  • 2306 Answers
  • Posted on Aug 31, 2009
SOURCE: My 2300W prints a second image
Yes, it sounds like a fuser problem, as the oil and coating wear off of the fuser rollers they transfer to the page as you describe. The only way to tell is to stop the machine in a print cycle before the fuser to determine if the problem is before or after the fuser.
Testimonial: "Very helpful and obviously knowledgeable gentleman"
Anonymous
  • 15 Answers
  • Posted on Jan 15, 2010
SOURCE: Replacing Image Transfer Roller Unit & Paper Dust/Ozone Remover
hi this unit located in the RIGHT DOOR
Anonymous
  • 319 Answers
  • Posted on Aug 02, 2010
SOURCE: cleaning dust off of mirror inside Konica minolta
www.rangefinderforum.com/forums/archive/.../t-5895.html
Lg 42lg70yd aa Weird screen problem
I've tried the link, but failed to see your youtube video. Anyway, if there are vertical lines, and all of them are closed to each other, indicates either a T'Con or Panel problem. To make it sure, just get into this link http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar or see it in Timeslide option. There are screen shots of different problems to flat panel TVs. Compare them to your TVs' and make sure about the fault.
I have a 50 in lg plasma tv model num50pk540 and when i turn it on it clicks right back off then again by itself 10 sec later
Hey Patrick...i know exactly what the problem is, and if you take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... Most likely it's your voltage regulator thats damaged, and needs to be replaced. I'm also selling a power supply board on ebay now, if you're interested, so check your board's model number to make sure its the right one. email at [email protected] if you have any question.and watch the video:
http://www.youtube.com/watch?v=I9wF0OLyV0k&feature=youtu.be
http://www.youtube.com/watch?v=vHrv5XaDULI&feature=youtu.be
50PK540 LG Will not power on
Hey Crystal...i know exactly what the problem is, and if you take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... Most likely it's your voltage regulator thats damaged, and needs to be replaced. I'm also selling a power supply board on ebay now, if you're interested, so check your board's model number to make sure its the right one. email at [email protected] if you have any question.and watch the video:
2helpful
Whirlpool duet GHW9100LWI, Makes loud noise in fast spin cycle
We have the same problem with many other with your washer.
You can have a look to the videos below
http://www.youtube.com/watch?v=HQCS3emiOpc&feature=related
http://www.youtube.com/watch?v=CmzMYfM7Ehw
And others
And compare to the one below which the last model which mean that whirlpool know the problem with previous models like your with loud noise and vibration.
http://www.youtube.com/watch?v=QczlYr5glsA&feature=related
You can try to unjust the feet and find a vibration elimination floor to put under just to minimised your problem but still a design problem from whirlpool engineer.
My Samsung HLN617 DLP is now dark. 3 small lights in the small circular display come on for a few minutes. Is the bulb easily replaceable for a novice or should I take the set to a repair facility?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9600224B and you can find it here:http://www.discount-merchant.com/Samsung-BP96-00224B-OEM-Replacement-LAMP-BULB-BP-p/samsung-bp96-00224b-oem.htm?Click=48173 .Here's how to replace it: http://www.youtube.com/watch?v=QQTKt9skeyEHave a blessed one!
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
