Hardware & Accessories Logo
Karen Ley Posted on Nov 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Woods timer #17321 not on - does it have an override?
Does the Woods 17321 Dusk-to-Dawn yard stake 3 plug timer have a manual override
Gene Haynes
Level 3:
  • Hardware & A... Master 5,391 Answers
  • Posted on Nov 23, 2012
Gene Haynes
Level 3:
Answers
5391
Questions
0
Helped
2603882
Points
14124
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Woods 17321 yard stake has selector dial on top.
Move selector to ON or OFF for override.
Unknown if override turns timer ON during daytime when photoeye is receiving light.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5 Related Answers
John Morganti
  • 864 Answers
  • Posted on Oct 29, 2009
SOURCE: I just bought a house with the Night Sentry EJ351
Here are the instructions: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
You will have to pick the times you want the lights to go on and off.
Anonymous
  • Posted on Feb 25, 2010
SOURCE: I have a utilitech 0192773 self adjusting timer
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
A
Anonymous
  • Posted on Sep 29, 2010
SOURCE: Woods In-wall Timer Heavy Duty, Model #59018 -- I
Quick answer:
1) Programming steps say 'press clock key to return to current time and day'
2) Use mode button and change between AUTO & RND >> try manual override in each mode
3) Does timer turn lights on-and-off with program, or do they blink too?
4) Swap Black and Red wires
5) Try timer on light in different room, on different circuit breaker
6) Timer might be defective
Longer answer:
Woods 59018 manual does not show troubleshooting steps except 'check wiring; switch Red and Black leads; and/or reset programming'
Seems unlikely you could program timer unless timer is wired correctly ... unless there is a short of some kind.
To review wiring.
Green goes to bare ground wire.
White goes to Neutral white wire (neutral is usually 2 or 3 white wires twisted together and shoved to back of box)
Black must connect to Hot from circuit breaker
Red must connect to Load (light, fan, motor etc)
How to test wiring
Disconnect timer and set aside.
Mark each wire
Separate wires in box so they don't touch
Use ordinary tester (you can tape tester leads to wood sticks)
Turn on power
You should have two black wires that were originally connected to switch
Test black wires to bare ground > when tester lights up, that is the Hot wire.
The other black wire goes to Load
Now you want to find the neutral.
Test the Hot black wire to white wires in box.
When tester lights up, that is neutral.
If everything checks out, I guess timer is defective.
A
Anonymous
  • Posted on Oct 22, 2010
SOURCE: I need instructions on how
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15107-Manual-eng-spn.pdf
Above is link to GE 15107 manual
This is a 15amp timer that can handle up to 1440 watts
How to set timer
Rotate center dial to set current time
Line up current time with triangle on inner part of dial
The timer dial shows nighttime hours on dark part of dial, daytime hours show on light part of dial
The timer dial rotates like a clock after it's plugged in
The outside edge of timer dial has 48 segments
Lift up these segments for times you want timer OFF
Segments down for timer ON
5c24d6c.jpgSegments up, timer OFF. Segments down, timer ON.
Segments in photo are on the GE 15207 timer
A
Anonymous
  • Posted on Nov 08, 2010
SOURCE: How to set utilitech wall timer for dusk/dawn
The Utilitec 0192773 timer has astro dusk-to-dawn functions.
The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
When you are programming the timer, press TIME button and hours start flashing.
Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
When the sun-moon symbol shows, the display also shows AM.
Press the +/- again and PM show.
So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
To continue setting astro, do not set hours, just press PROG button.
Then repeat the steps above until: 1 OFF AM sun-moon show on display.
I am trying to program a Westinghouse yard stake. It's a model 28006, hinge top, 6 outlet digital photo cell. Please help if you can.
1) Copy following link to help identify same-similar timer and download possible manual
2) On-line search shows dawn-dusk timer which can be set to turn off 1-9 hours after dusk.
Typical operation is to push button until 6 displays, then timer turns ON at dusk and OFF 6 hours later
3) Describe timer with more detail so expert can exactly identify timer functions and find same-similar manual.
Program GE 15147
GE 15147 is one-button timer outdoor timer.
http://waterheatertimer.org/pdf/GE-15147-Yard-Stake-Timer.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#tower
More 1 button dawn-dusk timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
WOODS TIMER - Woods 17321 Dusk-to-Dawn 3 plug yard stake timer
These household-type timers have 1 year limited warranty. Sometimes they last for a few months, or stop after 1 year, and occasionally they last longer 3-4 years.
Solution:
Buy another yard stake, or plug-in timer:
Example in-wall timer: Woods 49650-59204 at my house.
http://waterheatertimer.org/images/IMG_2060-woods-59204.jpg
Another handy thing is the Woods 32555 remote control. Let's you turn on outdoor lights from inside the car, or inside the home.
http://waterheatertimer.org/images/Woods-3255-image-500.jpg
Each item above is sold at Amazon, or local home center or hardware, or box store Sears-Target-etc
Woods vacation villa 2 room tent manual needed..Please help
Woods 83660 security timer appears to be same/similar as Coleman 2001/Woods 49647
Instructions: Timer turns ON automatically at dusk
Use dial to set 4 possible options:
Off = always OFF; ON - always ON
Dusk-Dawn = ON at dusk, OFF at dawn
2,4,6,8 hours = ON at dusk, lights OFF 2,4,6,8 hours later
Woods Model 2001-49647 manual
1helpful
I have a Woods Outdoor Lighting timer - model no. 961012, with a 3 outlet powerblock that I have connected 2 lighted Christmas decorations. I had it set for dusk to dawn, and everything was fine until I...
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
If this is not your timer, add a comment.
A number of folks are writing in about dusk-dawn-timers flashing.
The manufacturer suggests turning photo-eye away from all lighting when installing timer.
Always aim photoeye toward dark region of yard.
I would unplug the timer and let it reset.
Try timer again, turned away from lights so there is no feedback.
Put black tape over photeye and see what happens.
If timer still doesn't work, then timer is defective.
Maybe photoeye circuit was overwhelmed by intense light converted to electrical input.
I test timers, and 4-6% arrive defective, and most last just a season or two, and then you buy another, but the price is affordable.
Local Home Depot sells the GE 15107 outdoor yard stake or wall mount.
I bought one tonight for testing.
It has no photo eye
It has a dial timer where you set exact on-off times by moving plastic segments on dial perimeter.
For example set timer for ON at 5:30 and OFF at 6:00 am depending on your latitude north or south.
geno_3245_189.jpgphoto eye on yard stake timer
Need instructions to set this timer
You posted under a photo that looks like Woods/Coleman cable 2001/49647 timer
See image at Amazon
http://www.amazon.com/dp/B00002NB2X/ref=asc
If this is not your timer, see all Woods timers and manuals at following link:
Add a comment any time
Manual for Woods 2001-49647
http://waterheatertimer.org/pdf/Woods-2001-49647.pdf
Instructions:
Plug in timer, plug lights into timer, capacity 1875 watts
50-mini-bulb string of Christmas lights is 25 watts
Timer tuns ON automatically at dusk
Off = always OFF
ON - always ON
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
