8 bar light. Wheelchair just quit working. Have checked all connections, fuse...battery good. What can I do now
SOURCE: Jet 3 Ultra won't charge
You can find the Fuse behind the foot rest. Take the pin located under the foot rest, and the casing will come off exposing the fuse.
SOURCE: jet 3 ultra 3 Flashes The left motor has a short
Bad news; probably a short in the primary for the motor. This usually happens when the chair has been driven over unstable terrain, like wet, soggy grass and it bogs down in the muck. Driving it out while seated causes over-amping on the motors as they try to compensate for slipping, etc, and a motor will fry or a fuse will blow, or wiring harness will cook. You can replace the motor gear assembly for about $900.00, or try taking the motor to a rebuilder and have it rewound, which runs a couple hundred and the motor is like new again. Jack the left side up, remove the left wheel (make sure you save the key that fits in the slot on the axle! They get lost easy). unplug the motor and remove the 6 bolts holding the motor to the frame, disconnect the shift mechanism and the motor is free. separate the motor from the gear box and take the motor into the shop, reinstall and test run it. If the gearbox wasn't damaged, it should be good as new.
Good luck
SOURCE: jet 3 ultra needs new battery, where do you get
you can get them from batteries plus. make sure you look at your current batteries and request the correct volts amps and size.
SOURCE: Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
SOURCE: Pride Jet 2 power chair with with 3 red and 3
Hi. The fault code you have is called the "Inhibit active".
It can be caused by a blown charger fuse, which causes the charger inhibit to activate.
Also if the 3-pin charger inhibit connector is not plugged in properly, or the connector is faulty, then the charger inhibit feature will activate.
Hope this helps. Neil.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mi mobility
