KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Tom Oakes Posted on May 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water and ice dispenser and panel light stopped working.
Water dispenser, dispenser light and ice dispenser all stopped on our KitchenAid KSCS25FKSS01. Appears to be an electrical problem. Ice maker opperates fine, but nothing at the door mounted dispenser pannel works. Are there fuses somewhere? Suggestions? Thanks
  • Tom Oakes Dec 16, 2007
    How do I open things to get to these components? I can't even get the bezel off the water dispenser. Do I remove the seal around the door to pull the plastic interior out? THX Oakescreek
  • Anonymous Mar 29, 2014
    The light, water and ice dispenser in the freezer door of my side by side Kitchen Aid model KSCS25FKSS01 is not working, but the interior lights in the freezer are working.
Anonymous
Level 2:
  • Expert 89 Answers
  • Posted on Dec 16, 2007
Anonymous
Expert
Level 2:
Answers
89
Questions
Helped
45224
Points
190
Water and ice dispenser and panel light stopped wo - 02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Jun 05, 2007
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1202002
Points
3312
Oakescreek, start with simple things first. Check the freezer door light interlock switch. This has to be closed to send power to the dispenser. If that is working ok, check the harness coming from the bottom of the freezer door for cracked or split wires. Check the harness plug itself to make sure it is completely connected. If these things check out ok, we will need to verify that we are getting voltage to the dispenser selection switch. If we are and it is still not operating..then I would suspect that to be the problem. I'll keep and eye peeled for a reply. Catriver.
1helpful
2answers
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
1helpful
3answers
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
1helpful
Kitchenaid side by side frig (KSCS25IN) will not dispense cubes
Check the drive gear for the agitator, It might have gotten stuck on ice too many times and stripped the gear. Good luck!
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
