Can turn on system. can raise/lower. fans run, all lights appear norman. Until it's supposed to run or I try to push speed button. Then incline inop. Treadmill will not move on it's own. Belt/motor appear free. When I shut down restart if incline was up, returns to normal except treadmill will not operate. Circuit breaker appears normal. Had been stored for 1.5 years due to fractured ankle.
LUBE or wax the deck belt, this happen because you do not have schedule maintenance according with the owner manual. The machine shut down for autoprotection in electronic system Do it NOW.
2) LUBe the rollers bearint too with WD-40 only for rollers
3) Test the drive belt motor, for worn or cracking belt, replace or adjust it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubelshooting help.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
SOURCE: treadmill Stex 8020 when switched on immediately
If it reaches 250km then I suspect that the upper electronics is not functioning properly contact the distributor of Stex and If under warranty they sould cover it,but send out a servicer
Dear Sir:
I will try to help you.
http://www.soletreadmills.com/pdf/manuals_2009/SOLE_F80_83_85_2009.pdf
attached is the web page for Sole Company, for to download the user manual, and see what will happen with your equipment.
Thank you in advance, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
labeling lamps from left to right & then down: L1-L3 on top , L4-L6 next row, L7 on bottom. On startup lamp L1 is dimly lit, L2 & L3 operate according to up/down function. L4 off/L5 on L6 on/L7 off when unit asked to drive either manually or by system, L1 shuts off/LS indicationshows on Panel along with low speed.
