MY ARCTIC CAT WILL NOT RUN UNLESS I PUT GAS IN THE CYLENDERS. WHY WONT IT **** FUEL. I HAVE NO AIR LEAKS. AS SOON AS I TOUCH THROTTLE IT DIES. CARBS ARE CLEAN.
Have you checked your fuel filter?
Have you checked to see if fuel is getting into the carbs?
Also is your machine parked outside and is it below freezing? It happens to me often when my machine sits for a while. Water in the fuel freezes at the carbs or in the filter and won't allow fuel to get through. I put a little ceramic heater under the cowling and cover it with a couple old blankets. It usually does the trick in a couple hours. Then I run some fuel cleaner though it. g'luck
