I have a Samsung J1045 and it won't stop taking in water no matter what programe I select. The only way I can stop water going in is by turning off the water tap. Even on spin program, it still takes in water and even when I pause it. Hope you can help me?
SOURCE: Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
SOURCE: Samsung Washer WF306LAW stopped draining and won;t spin
Drained the water from the tub into a bucket. Since the water flowed through the disharge tub I knew there were no obstructions in the line. I then took took the discharge pump out and took it apart. Turned out to be a bobby pin in the motor that was jamming the impeller.
Put it all back together and it works just fine. Took me about 2 1/2 hours total to diagnose and repair.
SOURCE: M9503 washer dryer not draining before dry cycle.
Check these out:
SOURCE: unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Testimonial: "this is very helpful, Allthough I am not capable of carrying out this work I do at least know what the repair guy may say. thanks."
SOURCE: Hi,My Lamona HJA8514 will not
i think the program bord has packed up,,, but it could be a motor fault as well
