GE PFSS9PKy Refrirator Logo
Douglas Vanderhook Posted on Nov 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Filter light will not turn off - GE PFSS9PKy Refrirator
Richard Roth
Level 3:
Top Expert:
  • GE Master 9,472 Answers
  • Posted on Nov 11, 2012
Richard Roth
GE Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626563
Points
28464
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
How to change water filter?
Hi
Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill.
Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
1helpful
I have a Maytag window air conditioner unit (model M6T12FSA). The 'check filter' light came on and after I cleaned the filter, the 'check filter' light remains on even after a few hours of...
Turn the unit OFF & Unplug it. Remove the filter and reinstall it, being sure that it's installed properly. Particularly, which way the plastic filter frame is facing when installed.
Plug the unit back in and turn it ON. Hopefully, the electronics now will accept the filter being properly in place.
Hope this helps and thanks for choosing FixYa.
Where is the filter located in the refrigerator?
1. Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
2. Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill
3. Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
4. Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
5. Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
1helpful
How do i reset the filter light on my refrigerator msd278ge
Simply press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for four (4) seconds until the filter status indicator begins to flash, then release the buttons. On some Amana refrigerators, you need to press the dispenser lock and water buttons for four (4) seconds until the filter status indicator begins to flash, then release the buttons.
Also note that
  • Remove the old water filter from your refrigerator by turning the handle counterclockwise and pulling it out of the filter holder. The filter is located in the upper right corner of the refrigerator.
  • Step 2Slide the replacement filter into the filter holder and turn it clockwise.
  • Step 3Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • Good luck......
    9helpful
    Have replaced the water filter - how do i reset/turn off the "change filter" light ?
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • 0helpful
    My hoover HDC 75 will has the filter light on
    the only other filter is the condensor but that wont stop it from turning if there is a humming noise when its ment to be turning its sounds like motor,or capictor or the drum has jammed.
    Sep 29, 2009 • Dryers
    31helpful
    4answers
    Changed water filter red light stays on
    Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
    8helpful
    Kaz Honeywell Tower Air filter rest light
    When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
    monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
    filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
    your individual usage (environment and hours used), you may need to check and clean the filters more or
    less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
    should be reset at the same time.
    Filter light still on "Red"
    try holding ice type and child lock together for 3 seconds that worked on mine
    Top Refrigerators Experts
    vince
    Johnny 1000
