Refrigerator lines in frezzer freze up and not let air to top
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
SOURCE: My Amana refrigerator is not cooling top or bottom
check against the back wall to see if the fan is runningif it is check to see if compressor is running and should be warm to the touch if all that is running uve probably got a freon leak and unit is low on freon
SOURCE: Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
SOURCE: Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
