I can see my Inbox clearly enough but not the items I have sent or deleted text messages?
For sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
SOURCE: I deleted an important text message by mistake
Yes, there is a way to recover your iPhone SMS.
As a matter of fact, every time you sync data between iPhone and iTunes,
all previous data will be automatically backed up by iTunes and stored
as a .sqlitedb file, which will be updated along with the later sync
continuously. But those backup files can't be viewed or taken out unless
you use some software using special algorithms to extract.
Learn how to recover your iPhone data here with step by step guides.
SOURCE: i dont know how to save ringtones that were sent
You can't actually do this on the iPhone. The sounds has to be in the m4r format and has to be synced from iTunes.
Here is a good collection of tones ready to go for the iPhone: http://www.exectones.com
SOURCE: TEXT MESSAGING
If you mean that you don't receive the delivery report message, then it'doest exist at all in apple iOS (iPhone)but can be added by some apps. Check your operator. Good luck
SOURCE: I have deleted text messages from my iphone. I
The iPhone makes it possible to be interconnected and synced up, so you do not have to fear losing data or files again if you engage in some preparation. Accidentally deleted text messages from your iPhone, or even breaking or losing the device, does not mean that your data are gone for good.
Learn how to perform iPhone data recovery using software.
Dear friend,
You can ask your friend to resend the same recording to you via email or mms to your device.
Since, whatsapp does'nt provide other options.
Instead all these, try recording that clip to another device and send it to your iphone then you can use that as a ringtone.
Regards,
Priyank Abhineet.
