Noise during the spin cycle but it's still spinning. HELP??
SOURCE: kenmore series 80 washer makes
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete
and leveled to perfection, the force of a heavy wash load spinning in
excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the
shocks that are used to dampen the spin cycle might have been broken or
damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
SOURCE: washer makes noise during spin cycle, wont agitate
Sounds like your transmission is going out. Yes washing machines do have transmissions, I know, strange huh? Anyway, the transmission is connected to your motor and the motor makes it spin and agitate. The transmission goes up into the tub and is basically the agitator. When the gears go bad in it, it will start making a loud noise almost like a grinding noise and won't spin properly or agitate. It is expensive to fix, almost as much as a new washer. Your best bet is to buy a new machine unless you can find a good deal on a refurbished transmission. Those will sometimes run only around 150 dollars. A new one though will cost you around 250. You might be able to find a good deal though. They are easy to fix, I myself replaced one in 15 minutes once when I was still a repair man for Sears. So, check out some prices and see what the best way to go is for you. If you have any questions about installing it let me know and I can give you an easy step by step walk through on it. I hope this helps you out and good luck.
SOURCE: kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
