My refrigerator has the error code 'IF' on the front panel. We are unable to get ice or water within 3 minutes of unplugging and plugging it back in. Also, the temperature within the refrigerator and freezer seems warmer than normal.
What is the problem and how can I repair it?
Thank you.
Hi!!! You have a control board problem.Change the control board and you should be okay..Them boards did'nt come out good.Good luck..
Possible sollution...sears replaced a board last week as a recall for "energy rating" problem I now have that same code I am trying to find out which board they replaced; will submit asap
sears cannot tell me at this time which board they sent to my home....they say they will have the tech call me tomorrow to tell me and I will pass it along.
Code IF is ... ice fan...ie the fan in the ice maker is frozen. This is typically the ice fan sensor and easy to replace. The recommended procedure is to unplug the unit for 3-4 hours to allow the fan to thaw. They say this should stop the problem and it should not reoccur. They still will not tell me which board reads the information from the ice fan sensor, but I can tell you it was the main board that was replaced last week in my unit due to "energy efficiency" issues. They did slip and tell me it was the ice maker that caused the recall.
SOURCE: kenmore elite trio bottom freezer refridgerater 795 7555
there are 3 ways it can be held on,screws,snaps,clips or slides one way up or down or side to side,to make sure what you have get the model number from inside the frig. ,go to sears .com click on parts put in your model number and your whole frig diagram will come up and you will see exactly how it comes apart,let me know how you do-mike
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: The temperature settings for the refrigerator and
I have the same problem with this refrigerator. It looks like Sears Parts Direct sells all the parts for this unit except for the printed circuit board and temperature control switches. I called my local repairman and set up an appointment. He called back to cancel his appointment because he was also unable to get the electronics. Were you able to fix your unit? What did you replace?
SOURCE: I have a Kenmore elite trio 25" 795.77543600 three
Hello, stephen
I
am trying to help you out here. Maybe this will help some? I am know on
Fixya as the cleanup expert pro. Which means I spend my own personal
time to seek out customers that maybe have not had there problem yet
solved. I do this on my own for free. Think of me as a Specialized
Trouble Shooter.
I have found out that it appears that lots of
customers appreciate my efforts and help. So, I thought I would take
some of my own personal time to
see if I can help you. Even though this Informational site may not have
your exact model or brand, But this site will help you a lot. Here is
the site link about everything you want to know about refrigerator and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
Please
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help, I would appreciate it. Like I said I
just try to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
I am having the same error code, last week sears came out and replaced a curcuit board as a factory recall/ upgrade for "energy rating" reasons. I am calling them and asking which board was replaced. I will add the info asap.
IF code on kennmore elite trio
I have the DOE recall on my Trio, Sears did the upgrade and now I get ER IF. Sears is returning to install the third board. Can the quality be this bad?
