Philips 47PFL7403D 47 in. LCD TV Logo
Anonymous Posted on Jan 03, 2009
Need code for comcast remote control
47" philips lcd tv model 47PFL3603D/F7
Comcast DVR (HD) remote control
I can't find the code to put in for my new TV. I'm getting the run around from cable, who wants me to pay for a service call and have someone come out, and Philips tells me to go to the urc.phillips.com site and ''play around' and I ''might'' find it there!
  • 3 more comments
  • Anonymous Jan 03, 2009
    That is NOT the solution - we (Comcast and I had already TRIED using the codes in that manual that was written in July 2007 if you look closely at it - it is virtually useless to anyone unless they are looking for a code for an older television.
    I am not.
    This is a brand new model - Comcast does not have the code for it.
    Philips obviously does not either, or they would have given me a straight answer.
    Please folks - let's not give BS responses as ''expert'' answers - I have tried all this - I've been on the phone for days doing this, I just need to know if anyone has THE NEW CODES FOR PHILIPS 47" LCD TVS - not ones that are a year and a half old.
  • Anonymous Jan 04, 2009
    that is NOT the solution either bluextec3221 - as that leads you to the exact July 2007 list that was provided earlier.
    Does anyone here bother to look at the things that they send to people as solutions, or is it all a big race to see how many posts they can answer? I thought I was rather informative about the fact that manual was not of any help and that Comcast and I had already gone that route.
    I do not wish to purchase another remote - that was one of the solutions that Philips offered me, and they provided me with that link also. I paid $1100 for this TV - I am not going to go out an purchase a new remote to go with it.
    Comcast said they get their updated codes from the manufacturers, and the codes they gave me were the latest ones that Philips had given them.
    Philips sent me to the exact page that you sent me to ........ supposedly to ''fiddle around'' a bit, and I could ''probably'' find the code that I was looking for. There were approximately 10 remote controls they offered the codes for - with hundreds of codes listed. I called Philips back, and they sent me back there to look at the Universal Remote Controls they offered for sale, and where to buy them. That is NOT the solution either.
    There HAS to be a code in existance for this TV, and someone out there has to have it, but no one is willing to spend the time to find out what it is. Comcast is using the: Philips hasn't updated us yet answer, and Philips is using the: Buy one of our Universal Remotes, or search through our library yourself (which I tried, but there are just too many to even begin to try after you go down the lists for all the model numbers starting at the first - I got half way through before I decided to pay for the "Premium Answers" here at FixYa!
  • Anonymous Feb 16, 2009
    need code for phillips 42" lcd tv
  • Anonymous May 09, 2009
    well the code i used for my philips televion was 10054 it worked only half way though.... volume and power the tv on and off i still cant change channels.
Mandeep Singh
Level 3:
  • Master 1,184 Answers
  • Posted on Jan 03, 2009
Mandeep  Singh
Master
Level 3:
Answers
1184
Questions
11
Helped
474831
Points
3414
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
  • 1 more comment
  • Mandeep  Singh
    Mandeep Singh Jan 03, 2009
    You can try the following codes
    Philips 0035, 0081, 0618
    BUT, according to me this remote is not compatible with the philips TV.
    Thanks
    proton
  • Mandeep  Singh
    Mandeep Singh Jan 04, 2009
    As i wrote before ,my friend , if you could give me the model number of the remote that you have i may try to find a solution. Cause everything on the philips says the remote is not compatible with the TV you are using . So its better to change the cable provider.
    Thanks
    Proton
  • Mandeep  Singh
    Try adding 1 to the front of the code. "10054"'. Hope this helps
    This code solved problems for a lot of people using the comast remote.
    Thanks
    Proton
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2182
Points
6
I have a philips lcd tv and have tried for days to get my comcast dvr remote to program my tv. I used code 10054. thanks proton
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 04, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1993
Points
10054 worked for my 47 inch philips lcd hdtv
Anonymous
Level 3:
Genius:
  • Master 1,239 Answers
  • Posted on Jan 04, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1239
Questions
8
Helped
407310
Points
3279
Hi nancekelly ,
here are the codes 006,007,010,011
,013,016,033,035
    check this pdf guide there is full info about programing codes http://www.comcast.com/MediaLibrary/1/2/...
    http://www.thompsontv.com/rcarc.html
    and check here http://www.comcast.com/remotes/universal...
    If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.Example: You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
        Turn on your TV.
        On the remote control, press TV once.
        Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
        Using the number pad, enter 9-9-1. The TV key will blink twice.
        Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
        Press the SETUP key once to lock in the code. The TV key will blink twice.
    Note: Use the AUX key to program the remote for an audio receiver or DVD player.
    Checking the CodesIf you have set up the remote control using the Searching For Your Code procedure, you may need to find out which four-digit code is operating your equipment. For example, to find out which code is operating your TV:
        Turn on your TV.
        On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
        Enter 9- 9- 0. The TV key will blink twice.
        To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the TV key blinks (e.g., 3 blinks = 3) and write down the number in the left- most TV Code box (at end of this section).
    Note: If a code digit is "0", the selected mode key will not blink.
    Repeat step 4 three more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, and 4 for the fourth digit. To check another device code, repeat steps 1 to 5, but substitute the AUX key for the auxiliary device you are checking.
Anonymous
Level 3:
  • Master 15,935 Answers
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5036923
Points
35540
Https://www.comcast.com/corporate/customers/customer_support/remotes.html
there is the link. Since we dont know which remote you have, yuo'll pick it from a list, and go from there.
Anonymous
Level 3:
Genius:
  • Master 3,422 Answers
Anonymous
Master
Level 3:
Genius:
Answers
3422
Questions
Helped
1025562
Points
9479
    If you need anymore help let me know..
Ekse
Level 3:
  • Philips Master 13,435 Answers
Ekse
Philips Master
Level 3:
Answers
13435
Questions
82
Helped
3985155
Points
38023
  • Ekse Jan 04, 2009
    If comcast doesn't have a working code for their own product then who will?
    The remote most likely will not function with the set, have you tried code search?
    I would suggest to get another remote
    try one of the urc remotes
    http://www.universalremote.com/consumer/...
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
I can't get my Comcast remote control to sync up with this sylvania 32in HD tv. I tried every code in the Comcast DVR manual under sylvania tv's and nothing, I would love a fix to this problem.
the tv is likely to be generic in nature i.e. parts used by many manufacturers. if you knew what tv builder actually designed it you could find the code. does the remote have a search feature if so use it, it should find something that operates most tv functions eventually
35helpful
2answers
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Need Remote/Device Code for Comcast RNG 200 DVR
je recherche le code pour reprogramme d'une tv internet de model nritv2112 une tv bush
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
11helpful
6answers
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
129helpful
3answers
Help with comcast remote code setup for philips tv
Try adding 1 to the front of the code. 10054 worked for me. Hope this helps.
I need a universal remote control code
I am looking for the White Westinghouse sk26h240s remote codes for a Comcast universal DVR Remote control. any ideas, please email me at [email protected].
25helpful
8answers
Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
