I have lost all voice directions on my garmin 660 nuvi,i have tried restoring factory settings,i have tried re-setting it on the babck of my garmin,but still no good can you please help thanks
At first the ping sound was distorted, then the voice became garbled and then all sound was gone, all within an hour or less.
AnonymousJan 16, 2009
Today mine did the same thing, distorted ping and then all sound was gone within an hour. Today mine did the same thing, distorted ping and then all sound was gone within an hour.
In case it is a software problem try this and see if it will fix it....Try this and see if it fixes your problem...follow these steps. 1. Power off the unit. 2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least). 3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
It seems that it's a software problem ,. To software problem on your device , you need to reset it .
To reset your NUVI , please follow one of these procedurs :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented
by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation
message will appear asking to confirm restoring the Nuvi to factory
settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the
touchscreen [ Don't let go
] , and then power on the GPS unit. You should be prompted whether do
you really want to erase all user data, or asked if do you really want
to start up in maintenance mode. Press “Yes” to reset (warning: all data
will be erased and lost, so backup before proceeding) or enter
maintenance mode.
It's a common software problem with your device . To correct the problem I recommend you to reset it .
Here is how to reset your device :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings ............................................................................................ Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Go to settings, you will see blank box for language settings (where you tell it to use TTS or normal or other spoken language etc.) select language of your choice again. You will be all set. Nuvi tends to loose its voice settings sometimes.
This series of Nuvi has 2 sets of voices for several of the available languages. The standard set is pre-recorded words linked together to form directions. This voice is usually clearer. However you lose street names and expanded vocabulary. The Text-To-Speech (TTS) voices are reading letters to form words, and uses an algorithm to come up with the approximate pronunciation of the word. This may sound less clear, but provides street names. So, you can select a standard voice (settings-locale-voice language) and lose some functionality, or select one of the many TTS voices and try to find one that doesn't offend the ear.
i have been told that voice to street is not as clear as the voice just stating turns. If it really bothers you then try voice to turn. I cant remember the setting but it should work well for you.
Please see this link:
http://www.fixya.com/support/r1094734-no...
-Jim
