I have 1983 john deere 420 garden tractor that starts and idles fine but when you try to move the hydrostatic lever or engage the front or rear PTO it stalls out. I've already tried cutting seat switch wires and wiring them together to bypass, also tried a new micro switch at lever, but didn't test battery but it seams to be ok.
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
SOURCE: I have a john deere L120 riding mower with about
have a john deere zero turn that will not turn all the way over
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
after digging deeper, I found out my 2 amp fuse that looked ok was bad. problem solved!
