Hi everyone!
i am a programmer from India.
Ihave developed a complete software package for Retail Chemist in Foxpro2.6 dos. It has accounting module and i have also add module totransfer all the data into Tally 9.0.
Now as i have work so hard on developing it. i dont want anyone to steal my source code by decompiling.
Can any one please tell me, how can protect my foxpro exe from decompiling.
Waiting for help.
Thnak you.
Harish.
Work with foxpro databases by the use of next material dbf file repair software download
http://www.dbf.repairtoolboxx.com
You need the re-fox or fox shell
is works good
an from mexico
SOURCE: i can't add data in the database using vb
The database can be any like oracle.
Two type of connection u can make.
One of such connection is ADODB
The code is like
Dim ors As ADODB.Recordset
Dim oconn As Connection
Dim Qry as String
dim Qry1 as string
Set ors = New ADODB.Recordset
Set oconn = New ADODB.Connection
Chk_selectall.Visible = False
oconn.Open "Provider=MSDAORA.1;" & "user id = " & Username & _
";password = " & Password & ";data source = " & Conn_string _
& ";Persist Security Info=True"
Qry = "insert into table1 values (100,'we')"
oconn.execute "Qry"
If u select any data then u ve to use
Qry1 = "select * from table1"
ors.open "Qry1",oconn
do until ors.EOF
msgbox ors(0) & "," & ors(1)
ors.movenext;
loop
SOURCE: How to add a picture in a field in Visual foxpro.
The type of the field should be GENERAL.
Try this command: APPEND GENERAL <fld_name> FROM <url_file>
For example: APPEND GENERAL my_gral_fld FROM 'c:\my_file.jpg'
SOURCE: can you give sample source
Create a connection:
lcStringCnxRemoto = "DRIVER={MySQL ODBC 3.51 Driver};" + ;
"SERVER=200.1.1.1;" + ;
"PORT=3333;" + ;
"UID=booking;" + ;
"PWD=booking;" + ;
"DATABASE=booking;" + ;
"OPTIONS=131329;"
lcStringCnxLocal = "DRIVER={MySQL ODBC 3.51 Driver};" + ;
"SERVER=localhost;" + ;
"UID=root;" + ;
"PWD=clave;" + ;
"OPTIONS=131329;"
SQLSETPROP(0,"DispLogin" , 3 )
lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal)
Accesing data:
IF lnHandle > 0
cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype","cur_roomtype")
IF cmd > 0
BROWSE
ELSE
AERROR(laErr)
MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2])
ENDIF
USE IN cur_roomtype
SQLDISCONNECT(lnHandle)
ELSE
AERROR(laErr)
ENDIF
Creating complex sentences:
TEXT TO lcSQLcommand NOSHOW
SELECT Inventory.inventoryid, Inventory.date, Inventory.roomtypeid,
Inventory.sold, Roomtype.descrip, Roomtype.rooms
FROM inventory Inventory
INNER JOIN roomtype Roomtype
ON Inventory.roomtypeid = Roomtype.roomTypeID
ORDER BY Inventory.date DESC
ENDTEXT
cmd = SQLEXEC(lnHandle,lcSQLcommand)
Passing parameters to a query:
nValor = 12
cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype where roomtypeid = ?nValor","cur_roomtype")
Calling a Stored Procedure:
SQLEXEC(lnHandle, "call myStoreProcedure(@param1)")
GOOD LUCK!
Adobe programmers are acquirable on the retail market as an entire bundle customer package. The manufacturer provides complementary resources with complete retail versions only attainable. Once acquired, adobe provides several functionalities to the computer discussable. First the computer attains a multimedia capability audio video only mentionable. Second the adobe program makes an extensive media recognition with computers that require document decodes. The adobe bundle programs once acquired provides an entire experience. Refer from computer software retail markets to capture multimedia impressions.
