When computer is put on hissing sound and strange smell comes from the monitor. It fails to load the os also
Whenever you experience an unusual smell coming from anything electrical, always turn it off and/or disconnect it from any power source until you learn more about the problem. A fire can make make any problematic device seem suddenly unimportant.
An extremely common component in nearly any electronic device is a capacitor. The sizes vary from baby-tooth-sized to bowling-ball-sized found in the power box for most photography studios. The hissing sound is likely caused by one of these. The noisy capacitor may be going bad or another component or an electrical short may be causing it to get too much power. I've attached a video of what happens when capacitors get too much power.
An electrical short could also be causing both symptoms. If the smell is similar to burning organic matter, you likely have an insect (a crispy critter) that can be removed to remedy your problem. However, an electrical burn usually releases gases from burning rubber or plastic and has a distinctly different type of odor. If that's the smell and you are handy with a soldering iron, remove the cover to your monitor and look for signs of burning or overheating. Otherwise, the task should be left to an electronics shop for repair.
If this information was helpful, please click the thumbs-up button below.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
