I can recieve calls but not answer them and It vibrates when I plug it into the charger but the screen wont come on no matter what I do!
Pleas Help
I had the same problem just now with my iPhone 3G. It froze for like an hour and a half! I heard calls come in but wasn't able to answer because the screen wouldnt come up. I pressed the top clicker button and the main button for about 10 seconds and the apple logo came up (finallyyy). It took about another minute and then the screen came back up and prompted me for my passcode. I hope this can help you all!
When you charge your iPhone from the wall port, you must make sure your iPhone is fully off every time. it is essentially a mini computer and overheats if you charge it while its on. its fine if its being charged from the computer. best way to fix it is to plug it in the computer and either sync it or download new softwear for it, as this reboots the iPhone's system and inner working, which is what you would have to pay $20 to have someone at an apple store do for you.
Take out the sim, then press and hold the home & sleep button for 1- 15 seconds, repeat this and it will restart:)
Make sure the sound/vibrate switch on the top left side of the phone is set to sound, then push the volume control button just below the sound switch to raise the volume as high as it will go...you should see some indicators on the screen when you switch the sound on and raise the volume...hopefully that will help
I had the same problem.. none of the above worked! I held the home and the sleep button but it didn't work.. I had my iphone charging.. then I unplugged it and plugged it in and its working now!
hi i cracked the screen on my iphone 3g but i know how to take apart the iphone as i replace screens and black on iphone 3g/3gs/4g but i replace it yesterday and it seems to be on and vibrating and notifacation sound comes on now and again but screen is black even if i connect to itunes or press the wake or home button please help as the iphone is not my phone and i will have to replace it if not fixed soon
When i rebort my iphone 3g then the screen go to dark and dont turne on
but sometomes whene ipress power botum ,apple's logo was came but also dont came to system just apple logo
please help me
Have you tried going to the apple iphone website and looking for answers? It sounds like the back light may have quit working or battery bad or a software problem, not really sure because I haven't had any problems with my 1st gen Iphone I don't know about 3G iphones.
Tried to replace front screen and back of iphone.. But it back together and it doesn't work but it still vibrates.. WHAT CAN I DO?!
my iphone has a black screen
the screen does not turn on, but it bibrates when connected to the charger....
I had the same problem with the screen on the Iphone 3G going black but the phone still rings. Hold down the top button and the main button for about ten seconds. The apple logo will show up and reboot in about another 20 seconds.
I was using my phone and all of a sudden it went blank. Just like the other people with the same issues, I am able to hear incoming calls and so forth but screen is not coming up. I have tried the examples below but nothing is working! Help please
please help
my iphone 3g screen wont turn on
I had the same problem, screen was blank, phone still rings & vibrates but appeared nothing else worked. I held down the power button & the main button for about 15 seconds, the phone rebooted & appears to be working fine now...
