SOURCE: i have an oil leak at the gear shifter how do you
Putting it bluntly, remove the case cover, pry the old seal out any way you can without buggering up the case then slide a new seal onto the shift shaft and seat it in the cavity. The only other way is to remove the shift shaft and then pry out the old seal. Sort of the same thing but a bit more mannerly.
SOURCE: my radio on my82 honda goldwing dont have sound
(Better1969) is correct. I just bought a 1983 Aspencade and there was no sound to my speakers. The gentleman I bought the bike from supplied new speakers but I quickly ruled that out. There are 3 fuse links behind the left turn signal in the fairing. 1 was a 1 amp, 1 was a 2 amp and the blown fuse was a 5 amp. I didn't have a 5 amp so I put a 2 amp in its place. So far the sound is still working but my FM radio reception is very poor.
SOURCE: can i use 1988 goldwing alternator on a 1995
Yep, 1500 alternators should be interchangeable. You can't put a 1500alternator in an1800 though, or vice versa
SOURCE: Honda GL 1200 Aspencade Gold
I am TOLD that: Most motorcycle have the vin number on the steering head (that is located behind the headlight or fairing. If it has a fairing it will be hard to see. If the frame is the original there should be a sticker or tag located there on one side with the numbers on it and stamped on the frame on the other side. All HONDA goldwings model are located there..
I can't vouch for this being true on the Goldwing, but it sounds convincing
