Out ice maker quit making ice. No water is going into ice maker. The diagnostics for the ice maker are OK. Light blinks correctly when blocked and stays on when not blocked.
Hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
My Kitchenaid free standing ice machine has some kind of builup (mold?) on the inside rubber tubing. How can I disassemble the unit to clean it?
We cleaned our ice maker and it won't make ice.
I am forever calling to have my ice maker repaired. In fact I will be calling them tomorrow for the 3rd time. My sister my brother and my mother all have ice makers and never have this problem. I will be asking for a new ref. very soon.If this continues
do you have a water filter cartrige installed
Have you tried defrosting the ice maker? If water is going to it under preasure and it is(the water path) not clogged the the control valve is clogged or defective.
Water dispenser quit Tuesday night. Did some trouble shooting I found on line, including leaving the light on in the dispenser well, but no change. The ice maker is still producing ice.
Ice maker works but the door controls don't come on. so to get ice you have to get it out of freezer
