It worked on mine,
I pushed Mode, Power, Tare at the same time.
It came up in Cal mode.
I added penny's till it was 995 or so then added small pieces paper to it till it was 100 then up popped passed. I turned it off then it works fine now.
Thank You!!!!!!!
It didnt work for me anymore idea please thank you
Answer 3. I basically removed the 2 screws one under the rubber piece and opened it up carefully and re solder the white wire 2nd from left back on it's contact. And followed answer 2 to make it work.
My scale reads HHH and the only thing it can do is calibrate but after it flashes 100g then want me to place things on it, it just stays on ZERO?
On mine te 100 doesn't flash and te scale part won't change from zero and wen I tap the bottom it changes from zero what do u do not
SOURCE: when i turn on my digiweigh dw 100ax scales F--H
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Fixed my Fuzion Diablo, aweome !
fixed my DW-100AS, works like new...thanks!
20 nickles work
