that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
You may be recording things that have inbuilt security. Some of the things you get on Sky or Cable have security programs built into them, so that they cannot be recorded. When you record them they either come up as a static picture, or the picture jumps around, or it has a line through it. It's usually pay per view items that have these problems.
first of all you would need to have a Sky HD set top box.
The cables coming into the wall.. you said one was the terrestrial aerial and the other was a sky cable. In order for you to benefit from Sky HD you would need twin cable or two single cable running from your sky dish.(allows you to record a program and watch another etc.
summary:
skyHD box
two feeds coming from your dish,
there is only one place these can go as they are screw on ie F connectors. so they would screw onto input 1 and 2 on the back of the Hd box.
Run a HDMI cable from the back of the sky box from the HDMI port to one of the HDMI ports on the back of your telly. last but not least you would need to get a power cable (kettle plug) to power the thing.
In regards to your terrestrial aerial you can plug this directly into your telly or via your aerial in port on the back of the skyHD box. then you would have to run an aerial cable from the RF out 1 or 2 to the back of your telly this would allow you to record two things on your Sky HD box then switch to your built in freeview that your telly has.
I think its the dvd players internal settings that need to be adjusted. If there is a menu set the sky box to the connection it is plugged into. Although this might sound strange some units when you connect them up will play fine through that input but unless the settings of the player is adjusted iut will record a blank screen because its default setting for recording might not be either the connection method you are using or the input you are using. I hope this makes sense.
Hi there! Sorry but you can't unless you have My Sky/HD recorder. The sky decoder is simply a one channel watch decoder. You can only record a sky channel and watch the channels normally provided via your VHF and UHF aerials connected to the decoder or vice versa.
My Sky fixes that although you cannot record to a dvd disc on this thing and the privilege comes at a price of course!
