SOURCE: Getting it started
There is probably another little button near the trigger that you also need to push in order to pull the trigger. Kinda like having to push on the brake before shifting out of park.
SOURCE: Remington 10 Polesaw
S.A.E. non detergent 30 or chainsaw bar oil.
Hope this helps You
please rate me
SOURCE: My 106821A 10
According to the manufacturer... Saw has a gravity-fed oiling system and it is normal for oil to “slowly” seep when saw is not in use. Empty tank after each use to prevent seepage. If you empty before you store it that should do the trick. I hope this helps!
SOURCE: Remington Polesaw 10
Sounds like either the motor is going or that you need a new chain. Is the chain old and dull and is it difficult to cut wood? If so I would try running the saw without cutting and see if the motor smokes. If so the motor may be on it's way out. If you smell an electrical motor winding smell, it's probably time for a new chain saw. I don't know that I would get a new motor for yours as it probably at least $50 and you might want to consider going to another brand like Poulan. Hope this helps!
Testimonial: "Quick response and detailed. Thanks!"
SOURCE: repair part purchase
In answer to request Warren:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
$16.99 above.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
