How do you open the acme juicerator to clean out the extract
I have a 1962 manual which might be too old but here's what it says: When juicing is completed, simply remove the spring-clamp top, unscrew the wing nut or spring clutch that holds down the cutter blade, and all parts to be cleaned may be lifted from the base. Bowl and top, being non-porous, similar to glass, require only rinsing. Blade should be washed under running water, using a stiff brush. Since the basket is made of stainless steel, it, too, cleans easily. After taking out the the pulp, let cold water run on the outside of the basket while you brush the perforated section. Any remaining particles of pulp will be loosened and can be removed with a damp sponge or by rinsing. Dry and reassemble for next use. Turn machine on and let run a few seconds.
Hope this is of some help.
The Cover got busted by a pit and I can't find any replacement parts.
