I cannot get the Bulldog Deluxe 500 to program a new transmitter. I just installed the unit. I do exactly as the install manual says to do to program a new remote transmitter. The horn chirps and the LED flashes, putting the unit into programming mode. But when I press any button on the remote, I do not get any chirp or parking lights flashing. I have tried multiple buttons on the remote with the same result. If I pull the battery out of the remote, it goes thru the musical chimes, so I assume the remote is okay? Any help is appreciated!!! This is installed on a 1996 Pontiac Grand Prix.
SOURCE: Set up
Turn the valet switch on, start the car with your key wait 15 sec, press the * star button 2 times with the car running, it should beep and program if not turn valet switch the other way and try again, if still nothing post me back and we will go from there
SOURCE: Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
SOURCE: Bulldog Deluxe 500, remote not starting the the vehicle
Remove the battery in your remote for 15 sec, then put back in, start your car with your key, wait 15 sec, while the car is running press the * star button 2 times, it should beep , if not try it again, if still nothing post me back and we can go from there
After contacting Bulldog Tech Support, they told me to check the wire connections to the antenna at both ends. They felt okay, but after reseating both ends, it works now!
