I replace the ingine key but the remote fob remote key. I 'm having problem with the remote key , I need help . I need to reset the alarm in the pontiac, someone told me to disconnet the batery . I also see the valey switch, but dont know how to reset the alarm system ... pls help
Try to change the Key Fob's battery first and then have a look to this link:
http://blog.keylessentryremotefob.com/2014/01/2001-pontiac-montana-key-fob-remote.html
Hope it helps.
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
SOURCE: Kill switch is on and I cant deactivate
you to disconect the main harness from the alarm.and take your car to a alarm repair shop.
SOURCE: Please recommend good alarm + remote starter installer in NJ area
Stick with Viper no matter the price even if you have to get a mocel with less features they never wear out and 99% of problems aren;t from the product but from the installer whereas with cheaper alarms if you have a problem 99% of them are the product.
SOURCE: my viper 2 way pager remote will not arm or disarm
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
