Above range microwave model #40180082700
It's not a door switch the door switches will keep the oven from even turning on when they aren't closed that's why they use switches, it's most likely the magnetron, it's probably made by Toshiba or deawoo, they're both junk parts made from unpurre elements and made to die and early ***** at your cost. You can thank those manufacturers for planning this into your appliances.
SOURCE: Kenmore over the range Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: Over the range microwave oven.
This could the problem with door switch if its within warranty get it serviced by the company, if its out of warranty get done local service center replacement of the door switch will around $50 ,Please do not it yourself as there is high voltage parts in it .....................
Good luck....
SOURCE: Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
