I was talking on my phone and the screen went white. It came back for a day, then had zig zags of color across the screen then back to white. Cannot get regular screen back at all. Tried removing battery and putting back in. Tried reset by hitting send, ok and end at the same time. screen still partially white and 1/4 of bottom zig zag of colors. help please
SOURCE: white screen`
I was having the white screen problem and what seemed to fix it was to take the back panel off, remove the battery and clean the connections.
SOURCE: ZIG ZAG Lines on Screen, Computer comes to a halt. processes stop
resart in safe mode by tapping the f8 key as the computer starts , before it says "starting windows"
once in safe mode navigate to the controll panel, select DISPLAY, click the settings tab at the top, In the screen resolution box , set it to a lower setting , restart, if it works , save the setting and your done . If it doesnt, go back to display settings and change it to a lower setting and restart. you could also back the color quality to 16bit in the same place and this might help in some cases.
SOURCE: Blank or White screen on new Motorola Krzr k1 cell phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
SOURCE: Samsung SCH - U340 won't turn on
hold 9 while powering the phone up i had the same issue then i did some googling and it worked for me :D gald i could help. now refer to me as king mike bc i solved your problem :D
SOURCE: water damage on samsung sgh-a737
I had the same problem, when download came up i charged my phone. then i took out the battery and put back in and turned on. it worked but some buttons did not. so i pressed hard till it could recieve it and it did and now its fixed!
