Cars & Trucks Logo
A
Anonymous Posted on Feb 26, 2018
Step by step instructions to replace 1996 lexus es300 valve covers
Help, I need to replace the valve cover gasket on a 1996 Lexus ES300. It has two broken bolts that need replacing. I plan on drilling out and using an easy-out to get the broken bolts out. I'm asking for step by step to remove and replace the valve cover (anything to worry about?).
doug felsenthal
Level 2:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 140 Answers
  • Posted on Feb 26, 2018
doug felsenthal
Expert
Level 2:
Greenhorn:
Cheetah:
Answers
140
Questions
0
Helped
38171
Points
443
Nothing really - but I would use a good grade of gasket sealer when putting back together. Also remember valve covers only need about 20 ft-lbs of torque. Don't over do it.
2 Related Answers
Anonymous
  • Posted on Nov 02, 2009
SOURCE: 1996 LEXUS ES300 3.0L
i have prolem with my car p0753
Anonymous
  • 3917 Answers
  • Posted on Feb 10, 2010
SOURCE: How to replace spark plugs in a 1992 Lexus ES300
Please find the step step replacement of spark plugs in the bellow mentioned link:
http://wiki.answers.com/Q/How_do_you_change_spark_plugs_on_a_1994_Lexus_ES_300
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
How do you replace the Evaporation Control Valve and the ERG Valve on a 1997 Lexus ES300?
Anon, disconnect vacuum lines,wires, etc. and unbolt EGR from intake shown in 4th video link. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Toyota Po441 P0446 EVAP Vacuum Switching Valve VSV Testing and Canister...
How To Test and Replace EVAP Canister Vent Control Valve P0446
1997 Lexus ES300 Evaporation Control Valve Google Search
OBD II Trouble Code P0401 Insufficient EGR Flow
How to Fix P0401 on 1996 Toyota Avalon Testing The EGR Modulator Valve
Fuse box diagram 1996 lexus es300
On this website, you find fuse box diagram and description for Lexus ES300 (1996)
Lexus ES300 1996 fuse box diagram Auto Genius
1helpful
2answers
How to change wiper blades
The 2003 Lexus ES300 has the most common hook-end wiper arms. If you purchase the replacement blades first, there will be additional instructions/illustrations on the replacement packages. Locate and press the tab or button where the wiper blade is inserted into the hook of the wiper arm and pull wiper blade out of hook. You may have to rotate and flex the blade to make enough clearance for the hook to pass through.
2003 Lexus ES300 Wiper Blade Videos (hook-end arm)
2003 Lexus ES300 Wiper Blade Size Options w/Correct Lengths & Attachments
2helpful
How to change valve cover gasket and thermostat on 1992 ES300
the thermostat its located in water out hose near to a/c compressor, to change valve cover, front of engine remove the plastic cover with lexus logo using hex 5mm key 2 bolts , unplug 3 spark plug wires ,loose all 10mm bolts on valve cover , to rear engine valve cover remove before the manifold intake and all components , air filter duct , etc.
Valve cover gasket leak on 95 lexus es300. how do i fix
Take the valve cover bolts off then get the new gasket on or use permatex gasket glue than put it back together
1helpful
3helpful
1996 Lexus ES300 replacing starter
the starter is in the wright side of the motor under the cruis controls. remove the black cover and youll see it....
1helpful
2answers
2answers
1995 lexus es300
Not the oil pump, the most likely cause is the intake and exhaust valve seals, this accounts for the smoke on start up
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Lexus Expert? Answer questions, earn points and help others
