Message: FAT is corrupted please connect to PC and recover FAT files. Our Fuse is new and after downloading about 150 songs it worked fine for a day but when the unit was turned on the next day the "FAT is corrupted" message came up and the Fuse is locked.
The files were downloaded from an HP computer but now we must use our Toshiba laptop away from home. However, we are fairly sure the error message appeared before we ever attached it to the Toshiba.
Thank you for taking the time to read this.
Mary
SOURCE: message says FAT corrupted
FAT stands for File Allocation Table. It is basically the table of contents like a book would have. It tells whatever device is using it where the information is stored on the memory. If there is nothing on it that you absolutely need saved, I would connect it to a computer and format the card.
SOURCE: FAT is corrupted
do u have a pc try reformating the mp3. in a pc u would first copie all the music to a folder(backup) then right click on the mp3 in my computer and select reformate drive and go through the prosses
SOURCE: i have a sansa fuze 8 gigs, FAT is corrupted, can it be fixed?
Hi, dont worry your player is probably fine, you just need to refomatt it. Checked out the sanza forum and they were pretty helpful
This guide should be useful
http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&thread.id=11867
SOURCE: sansa fuze FAT error
Plug your Fuze into your computer. Open "My Computer," right click your Fuze and click "Format," a window will pop up with settings on how you want to format it, make sure it's set to FAT, then click "Format."
fat is corrupted how can i fix it
fat is corrupt wont let me reformat it either
my sansa mp3 was shown FAT file is corrupt how can i solve this problem plz helps me
FAT IS COURRUPTED!!!!!!!!!!!!!!!!!!!!
My Sansa Fuze screen will say when i turn it on that FAT is corrupted I Connected it to my computer but i don't know how to fix the problem if someone knows how will you please help.
my Sansa mp3 is corrupted and I need fat
