In the last couple days the fridge has been flashing the ice/water dispenser lights while making a clicking sound. The first time after a few minutes it went off on its own. ( While talking to the service person for LG) She claims its in auto-defrost mode and the unit is okay should only be a few seconds. I have had the unit for over a year and never seen this from the unit. It went off again tonight for over over 15 minutes, I finally started pushing the buttons on the fridge., The water/ice/crush button it changed the timing of the pulses. If I use the lock button if turns it off. If I unlock it, it starts to flash again. Whats up with this piece of ****? Also found numerous post of other problems as well as the EStar issue.
http://www.energy.gov/news/6740.htm
http://www.consumeraffairs.com/homeowners/lg_refrigerator.html
SOURCE: water/ice dispenser sticking on
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
SOURCE: My LG refrigerator is not
There are a few reasons why your water may not be working. The first is that the fresh food side of your fridge is too cold and it has frozen. You can check that by removing the crisper drawer and checking the reservoir behind it. You can thaw the water with a hair dryer on low setting.
The next possibility is that it is your filter. If you have not replaced it in the last year, now would be a good time to consider doing so.
The last and most probable is that the water valve on the back of your fridge has failed, and not letting the water in for the ice maker and water dispenser.
This can be replaced by unplugging the fridge and removing the rear cover. You will see the valve where the water line is connected. There are several variations of this valve and you can click the link below to match up what you have.
Once you have matched the valve up, you can replace the cover and plug the fridge in. One of the biggest reasons that I use the site below is that they have excellent service after the sale including support for installing your part; according woth the right model, CHECK REPLACEMENT HERE.
Keep us updated.
