SOURCE: uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
SOURCE: Describe your uline wine cooler Problem
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
SOURCE: Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
SOURCE: No instructions for installing new seal on door
Service and parts manual is here.
http://stroboflash.com/searayproject/Docs/U%20LINE%20Service%20Manual.pdf
The procedure is as stated in solution 1 by expert Ironfist. The older units had a metal plate with screws that you had to loosed the screws in the retaining plate by peeling the gasket in the opposite direction without tearing it to loosen or tighten the screws on the retaining plate. Then you just lifted the gasket off. When you go to reinstall as previusly stated by the other expert... start in the top center and work to the corners. Make the coners fit before moving down either side to the bottom corners. Again make the lower corners fit and finally install the gasket across the bottom. Once installed rub the gasket mounting area smooth with one finger or thumb.
You have humbled and hornored me with your request. If there is something that your really having difficulty with once you start this gasket change just repsond here and I will get back to you ASAP but, we will complete the task!
Thanks again,
Kelly
