LG WM-2277HW Front Load Washer Logo
Anonymous Posted on Mar 06, 2017
WM2277HW LG Tromm washing machine won't start. Finding correct parts is not so easy. Why?
WM2277HW LG Tromm washing machine won't start. An appliance repair man said it was the Main Control Board. He also said I should replace the Display (interface) board at the same time. The cost of the repair is $585, so we decided to fix it ourselves. We ordered the parts with the help of a parts specialist. Well the parts were not the right ones. A little frustrating, not having a working washing machine. Well I think I've figured out what part numbers I need. So part number 6871ER2078A DOES NOT FIT, but part "6871EC1116A" does fit! (That is the display board). Part number 6871ER1078T DOES NOT FIT. I think the replacement part "6871ER1003C" will work, after searching the internet and looking at images of the part, though it is not the exact same one as in our machine now. Why do parts say they will fit in our model of washing machine, and then NOT fit? I am sure I am not the first person to order the "supposed" correct part only to find it doesn't work with the wiring connectors. Sigh. By the way, my LG washing machine was built in 2002.
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Mar 06, 2017
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
869590
Points
8043
Have you tried eBay for the parts?
2 Related Answers
Anonymous
  • 487 Answers
  • Posted on Jul 09, 2008
SOURCE: lg wm2277hw washing machine
sorry to say it but i think you still have a faulty hall sensor.
Try another one and send the last one back as being faulty.
It means the motor gets the power but the hall sensor stops it dead in its track
Anonymous
  • 1543 Answers
  • Posted on Aug 13, 2009
SOURCE: Humming sound washer won't spin
It sounds like you have a hall sensor failure, if your machine fills with water and then does the buzz thing without the drum ever moving in the cycle.
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
2answers
TE code on LG Tromm WM2277HW
Bad thermistor. Easy replace. $10 part. Check out videos from repairclinic.com or AppliancePartsPros.com.
My lg tromm model number wm2277hw/01 has the error code le show 2 seconds into the cycle even if nothing is in the washer what is going on
Hall sensor needs replacing (motor position sensor). Pretty easy and under$20. Check out appliancepartsproscom, repairclinic.com or YouTube for how to videos.
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
3helpful
I have the LG Tromm, WM2277HW. I followed the
I took the entire washing machine apart. I checked the drain pump as the repair service said I needed a new one, as well as a rear and front drum, shocks rear bearing assembly. Would you believe the only thing wrong with the unit was that the drain pump was clogged at both ends. Machine is running fine and not throwing the LE Code. The repair service (LG recommended dealer) should be shot for telling me to throw out the unit.
LE error
try using a-fresh its should help you out.
Turned on my washer a TROMM LG wm2277hw and at every cycle turn it beeps LE
LE means a faulty motor. The motor is called the "stator" in this machine. Located behind the back panel. Pretty easy to replace in this machine. Replace the stator and it will work like new!
2helpful
Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
