Sony Trinitron - however at least 10 years old! Works fine with analog and DVD player, but when connected HD digital set top box, there is no colour - running through video channel. The picture is brilliant - get all channels but no colour. Connected with indoor aerial, with about 81% strength, 100% quality signal. Have connected box to tv with outdoor aerial no probs. Have checked the TV has PAL or AUTO as colour setting. Have reset channels - no change. Please help!
SOURCE: TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
SOURCE: I need to set digital
You need to switch the TV to digital mode before you run the auto-program. Press the "DIGITAL/ANALOG" button on your remote before you run the scan. After switching to digital mode please complete the following steps to run the auto-program:
1. Press the "MENU" button on the remote
2. Press the right arrow ">" button on the remote once to highlight "CH" (looks like 3 boxes)
3. Press the "+" button (in the center of the arrow keys) to select.
You will now be in the "Digital Channels" menu. If you are in a menu called "Channel Setup", you are in the wrong mode. You should exit the menu, press the "DIGITAL/ANALOG" button on your remote and start again at step 1.
4. Press the down arrow on the remote to highlight "AUTO PROGRAM"
5. Press the "+" button (in the center of the arrow keys) to select.
The auto program will now run. This could take a while to complete but a progress bar is displayed so you can see how far it has gone.
If you can't get this to work or need further assistance, please post back.
Regards,
BElectric
SOURCE: Sony Trinitron KV-27TW77 will not
You have not cleared the number of programs tuned in the auto mode,if only one program is tuned than only remote or TV will will not change channels,check by tuning with cable connection with multiple programs,you will get the solution.
SOURCE: Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
