Can on the machine but code come out
Sir help me I have canon if 7105 code error 000004-00001
Thats the fixing unit has overheated. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR).
The difference in the readings of the main thermistor and the sub thermistor is 50 deg C for 1 sec or more. (main thermistor reading>/=sub thermistor reading) what you can Check the mounting/soiling of the main thermistor. Replace the main thermistor. Replace the AC driver PCB. Replace the DC controller PCB.
If you have more than 200 000 prints need to be replaced: Fixing assembly 230 V......... FM2-0174
Inspect thermistor and switch on FIXING UPPER FRAME ASSEMBLY
